Unable to DVR SuperBowl?
It appears that I am unable to schedule the Super Bowl to record? Found an issue similar to this a few years old. I’m out of town and would like to solve without needing to be in front of my server.
I can record the pre and post game stuff.
Are you seeing any errors in your server logs? (Or can you post them covering the time period when you attempted to set a recording?)
I was just able to set a recording for the Super Bowl, so perhaps it is something with your EPG data. Have you tried refreshing your EPG and then attempt to schedule the recording again?
I’m a little limited with what I can do as all I have is an Android Phone to try and mess with it.
It appears that a Guide Data refresh seemed to have solved the issue. Thanks for the suggestions!
