Hey all, I’ve been trying to get my server to be available remotely but can not get there.
I’ve tried all the suggestions I’ve found so far including:
No IPv4 reservation - no port forwarding on eero - no manually specifying port in plex
Yes IPv4 reservation - no port forwarding on eero - no manually specifying port in plex
Yes IPv4 reservation - yes port forwarding on eero - no manually specifying port in plex
Yes IPv4 reservation - yes port forwarding on eero - yes manually specifying port in plex
No IPv4 reservation - no port forwarding on eero - Yes manually specifying port in plex
I know that the eero supports UPnP and it is turned on. The only two settings I haven’t played with are the IPv6 (heard that turning off could help) and changing the port forward protocol on the eero. Seeing that I chose the TCP & UDP option instead of choosing one or the other I don’t think that’s going to make a difference.
Any guidance would be much appreciated! Thanks!
