Unable to Input Manual Connection IP or Port (Android)
Server Version#:
Player Version#: 8.27.2.29938
I am currently trying to configure the manual IP connection on my Android app player. I am able to slide the status bar in the top right of the app, enabling manual connection entries, however when I press on the screen area where an IP or a Port should be entered, no dialog box/keyboard pops up. The same is true for either of the two manual IP and Port entry locations for the app. I haven’t tried an uninstall/reinstall yet, but per the Play Store, my app is up to date and was wondering if there is something else I am missing???
Just did an uninstall and reinstall of the app. When I try to enter the IP address, the dialog box appears to be depressed as if the app is going to enable the keyboard for me, but then the app abruptly restarts.
Fixed in 8.28.0.29906-beta.
You can download & sideload the current beta.
You can join/leave the beta program in the Google Play store app on your mobile device.
New beta version works (regarding manual connections input) Thanks for the quick response!!
