Unable to load channel mappings
in dvr setup I select my hdhomerun and it ask for zipcode I put it in and says loading gets 88% then this Unable to load channel mappings.what gives?
I am using Ubuntu 14.04
I have exact the same problem. But I’m choosing Russian Federation/Moscow on EPG page. It loads list of providers, and then fails with “Unable to load channel mappings” message. I’ve also noticed that https://www.plex.tv/features/live-tv-dvr/#remodal-channels form also fails to load channels from time to time. I think that this may be related.
I have the same problem. Unable to load channel mappings!! come on plex! I also can’t add a new dvr. It just says error communicating with provider
Same problem…unable to load channel mappings and if I remove the dvr and I try to add again I must manually insert it … and after many attempts it load the device (HDHomerun) but not the channel mappings from plex.
I use W10 with HdHomerun.
