Unable to Login with Chrome
Server Version#: 1.19.1.2630
Player Version#: 4.22.3
I have migrated my Plex server to a new server, and after doing so, I have not been able to login via Chrome. I have cleared all the Cache/Cookies from Chrome, on all of my devices that use Chrome. Microsoft Edge works just fine. What could be the issue? I have attached a screenshot of what I see when trying to login.
Hi mattpatten,
Plex is more or less designed for Chrome, but extensions can be the reason for your issues. Try disabling extensions one at a time until it works, some are well unoptimized :wink:
Also if you have Chrome’s pop-up blocking feature enabled, try disabling it. Or just allow exceptions for app.plex.tv and the IP address of the Plex server.
Popup blocker… That was the issue. It wasn’t even notifying that it was blocking… Thank you for your help.
No problem, glad it worked.
