Unable to play video with HDR remotely
Hi, i’ve stored videos in my wd mycloud nas, and everything work fine when i play video in my home, but when i play from my friend’s house (by plex application in google chromecast TV connected in fullhd television) i can’t watch 4k HDR video (instead 1080 and 4k works fine), i tryed to activate DNLA, change transcode option in server, i tryed to change video resolution in plex setting option in app even in 720p but in this way occurred a error also with normal 4k video.
When i click to play the 4k HDR video a message appears with impossibility to play video.
any suggestion?
thanks.
  1. Don’t stream 4K HDR video to a 1080p (FullHD) TV
  2. Don’t stream 4K HDR video remotely.
  • Direct playing 4K HDR video remotely generally requires a fat Internet upload pipe. If you don’t have enough bandwidth streaming will fail.
  • Your NAS is not powerful enough to transcode 4K video or perform HDR->SDR tonemapping (see NAS Compatibility List). Forcing a video transcode by changing resolutions will fail.
  • Plex transcodes all video to H.264 which does not support HDR.
  • DLNA only works over the local network, not over the Internet (at least not w/o a lot of work).
Thanks, in according first of all i have to correct myself because the tv is HD not fullHD!
Based on your answer i’ve tried to watch 4k HDR from smartphone android with a 4g connection (not from the same wifi network) and it works fine (just the message to buy a plex pass to watch HDR), so i supposed that the Nas transcode work pretty fine, at this time I supposed it’s a problem of television (despite i’m using a chromecast tv that support 4k HDR).
But I don’t know why i can watch 1080p and not only 720p because the tv resolution…
