Unable to rename smart collections
Server Version#: 1.40.2.8395
Player Version#: Plex Web 4.125.1
I noticed that I’m unable to rename smart collections sometimes after creating them. It took me a bit to figure out how to connect to the container Plex runs under in TrueNAS, but I finally found how to do so using the heavyscript tool. Doing so, I connected to the container, and when I tried to rename 000: HEAVILY PLAYED to 000: HEAVILY PLAYED X, I see the following error in Plex Web:
And when tailing the logs, I saw these two lines in Plex Media Server.log:
Apr 29, 2024 03:02:00.525 [139792003980088] INFO - Request: [REDACTED_IP:48960 (WAN)] PUT /library/sections/17/all?type=18&id=152949&includeExternalMedia=1&title.value=000%3A%20HEAVILY%20PLAYED%20X&titleSort.value=000%3A%20HEAVILY%20PLAYED%20X&title.locked=1&titleSort.locked=1 (9 live) #1c1f37 TLS GZIP Signed-in Token (jasmeralia) (Chrome)
Apr 29, 2024 03:02:00.526 [139792215595832] INFO - Completed: [REDACTED_IP:48960] 404 PUT /library/sections/17/all?type=18&id=152949&includeExternalMedia=1&title.value=000%3A%20HEAVILY%20PLAYED%20X&titleSort.value=000%3A%20HEAVILY%20PLAYED%20X&title.locked=1&titleSort.locked=1 (9 live) #1c1f37 TLS GZIP 1ms 522 bytes (pipelined: 19)
Any ideas why PMS is throwing a 404 on this request from Plex Web?
Just wanted to bump this up as it’s still happening under Plex 1.40.3.8555 / Plex Web 4.129.1. Any suggestions would be appreciated.
Can you try optimizing your database from Settings > [Server Name] > Manage > Troubleshooting to see if that fixes the issue?
I can’t seem to reproduce it anymore, there’s been at least one release since this post and maybe it optimized during the upgrade? But I ran the optimize db and bundle cleanup tasks just to be sure.
