Unable to save mobile data
Server Version#: 1.23.2.4656
Player Version#: 8.18.2.25850
Despite I set all the options to save mobile data on my android app, when I play a movie it uses the exact amount of data as the file is on the PMS.
In settings → quality I choose “Set automatically quality”, "Limit mobile data (320p) and “Remote quality (320p).
IN advanced settings, I choose to not download content”
In avanzate su Riproduttore ho tolto la spunta “Prefer download content”.
What should I change also on my PMS settings to not use 2,40GB of mobile data when I play a movie of 2,40GB ?
Do you mean “Automatically adjust quality”? If so, turn that off. That allows the app to use a higher bitrate than what you set.
