In my quest to speed up loading times in PlexConnect I've noticed that my PlexConnect client on my ATV needs an active internet connection to connect to my PMS. Whenever I'm logged in to my MyPlex account everything works fine, but when I don't have an internet connection (or not logged in to MyPlex) it just displays "No Plex Library Sections Available".
Is it not possible to connect directly over my local network with GDM? GDM seems to discover my PMS server, but my logfile reveals an "Unauthorized" message. Is there any way to fix this?
These are my current settings:
ATV model + firmware version : ATV2 v5.3
The DNS server set on the ATV: 10.0.1.1
The local IP address of the device that PlexConnect is installed on: 10.0.1.22
The device and operating system that PlexConnect is installed on: ATV2 v5.3
The device and operating system that the Plex media server (PMS) is installed on: Mac Mini (Late 2012) / OSX 10.10.3
The Plex media server (PMS) version number you are running: 0.9.12.2
The local IP address of the device that the Plex media server (PMS) is installed on: 10.0.1.10
The PlexConnect version number: 2015-06-02 20:55:01 CEST
Settings.cfg:
[PlexConnect] enable_plexgdm = True ip_pms = 10.0.1.10 port_pms = 32400 enable_dnsserver = False port_dnsserver = 53 ip_dnsmaster = 10.0.0.1 prevent_atv_update = True enable_plexconnect_autodetect = False ip_plexconnect = 0.0.0.0 hosttointercept = localhost port_webserver = 80 enable_webserver_ssl = False port_ssl = 443 certfile = ./assets/certificates/trailers.pem allow_gzip_atv = False allow_gzip_pmslocal = False allow_gzip_pmsremote = True loglevel = Normal logpath = .
- PlexConnect.log: http://pastebin.com/0uG66h7L
