Server Version#: 1.22.1.4228
Player Version#: 4.53.0
Good morning!
I have a problem that I hope I can get some help with. I am unable to access plex on the web app unless is I access it unsecurely. In 2019 I moved my PMS from Linux to Windows. When I was on Linux, I was able to access it securely. I had that computer set up for around 2 years. Me being a simple person, wanted the simplicity of a windows build. So in 2019 I reformatted the computer and installed Windows along with PMS and was able to save the metadata so I didnât lose any art, playlists, watched/unwatched media, etc.
That being said, I never got it to work on HTTPS and had to default to HTTP which has been a pain because I would like to remote view my media w/o security concerns. Basically, every time I open a new tab in a browser and go to plex web, I get greeted with the orange exclamation points next to my libraries and the âapp.plex.tv is unable to connect to âServer Nameâ securelyâ message when I select a library.
I use a Verizon G3100 router and can supply logs if needed. I mention the router because Iâm not sure if it is a router issue or something else. Thank you for your time and for any help you can lend.
Edit: I just want to add as pointed out below, when I set the server to Secure connections: Required, thatâs when I get the error. When I set it to Preferred or Disabled, It works but under those 2 settings it defaults to an unsecure connection.
