unstable installation of rasplex
Hi I downloaded the latest version of rasplex 1.6.2 used the rasplex installer to flash it on a 15gb microsd card popped it into my pi3 and when it did boot into the plex desktop it was extremely unstable, particularly if i touched one key on the keboard it crashed. I tried it with the pkex remote, same again
help please
I’ve never heard of a 15gb microsd card. But I would venture a guess, that your card maybe damaged and corrupting the image as you use it.
Try imaging it again. If no good, then try a new sd card.
I found a cure. I had the pi3 attached to a dvi monitor and it was very unstable. Attached the pi to a tv and run a newly flashed sd card and rasplex was stable had to do this again when the pi was in its final resting place, at the back of my terrible samsung tv and all is well
My 2nd Pi is also attached to a DVI-Monitor - no problems so far
