Update 1.32.0.6918 - Unable to load - refresh metadata
I installed the updated server version 1.32.0.6918. Since then none of my movies/TV shows added are not having their metadata loaded… I went into settings / libraries and the mapped drives are no longer accessible via the "browse for Media folder’ … just wondering if everyone else is experiencing the same issue?
Many thanks
I had exactly the same issue. After some digging it seemed to be because I have mappings from fairly old NAS’s and the file sharing protocol used is CIFS / SMB1.
I downgraded my plex server installation back to Version 1.31.3.6868 and everything sprang back to life. I’ll be holding off on any upgrades for the foreseeable future!
You can find more information about this in here: UNC Path not working following update to 1.32.0.6918
As well as a possible workaround until a fix is provided.
