Server Version#: 1.19.5.3035
Player Version#: latest on nvidia
I’m trying to update my windows plex server to the latest beta. The download completed and each time I choose the install option I see the spinning indication on the left for about 12 seconds and the install fails with a 30002 code. Suggestions appreciated!!
Plex Media Server Logs_2021-01-31_14-29-31.zip (1.4 MB)
Update “manually”:
- Stop/quit/end Plex Server with the tray icon
- deinstall Plex Server with the regular ‘Apps’ control panel of Windows (do not use 3rd party ‘Uninstaller’ software like Revo etc.)
- for safety, reboot Windows
- download the installation exe of the newer version and install it
(If you want to install an older version of PMS, take a look into %LOCALAPPDATA%\Plex Media Server\Updates)
Thanks. If I use that method, is there a way to retain my installation data? I do not want to loose information on my media database, that would take days to reconfigure.
If you heed this warning
Disable any Registry optimizer/cleaner software.
then you won’t lose anything.
Thanks for the reply.
So uninstalling with windows button → plex media server right click uninstall won’t remove the config info in the registry or in
C:\Users[username]\AppData\Local\Plex Media Server?
