Update is not working
Hey Guys,
i’m running a PMS on Windows 10. Everything works fine for me exept the Update.
PMS tells me there is an Update and nothing happens then. I refresh the Page and PMS tells me again, to update.
If i’m downloading the Update manually and install it, it works.
I read on Reddit, that it could be the Service. But i dont know how to figure out, if PMS is running as a Service.
Hope someone can help me.
Thanks in Advance.
Cheers
Server Version#:Updated
Player Version#:Updated
They probably meant the ‘Plex Updater Service’, which is always there and has nothing to do with running plex itself as a service:
Thank you!
That fixed my Problem and PMS is now working as designed :slight_smile:
Thank you, thank you, thank you!
