Updated a TV Series. Now it wont play.
Plexers,
I have been using Plex for a while now and not had too many issues. I recently decided to update my copies of Seinfeld from a low quality version to 720P versions.
I removed the old versions from my Plex server and added the new versions, completed an update and refresh etc and everything seemed to work fine.
I went to watch an episode on my Sony smart TV and I keep getting the following error, no matter what episode I try to watch.
“Playback has stopped because the connection to the Plex Media Server has been lost. Please ensure the server is available and retry.”
Now I know it sounds like an easy fix, but its not. I tried several other TV Show and Movies and they all work fine. I double checked the video file format and its .MKV, I tried other .MKV videos and they all worked fine as well. Its purely just Seinfeld.
I even completely wiped my Plex server and started from scratch to see if that would fix it, but im getting the same error?
The Seinfeld episodes work fine when playing to my PC / Smartphone / Tablet, just not to the Plex App on my Smart TV.
Does anyone know any way of giving me a hand here?!
Try to perform a new Analysis of your episodes.
(Switch Plex Web into the ‘Episodes’ view mode)
Exchanging the files right under the butt of Plex is not nice. :wink:
A better way would be to add the better files beside the original quality files, then update library, then remove the older files and update library again, then empty trash.
