Updated to most recent PlexConnect
Hi folks.  I updated to the most recent PlexConnect available and was able to get to my PMS content by logging into myPlex.  The myPlex Tab has my Movies, Music, Picture and TV Show libraries. However the Libraries tab and the Channels Tab give a message that it cannot be loaded or reached.
I did this a couple of days ago and don't have the exact message, but I've been looking thru the forum here to see if this is supposed to be the case or if I need to change something. From what I've gathered this would be case if i were doing this remotely outside my network with myplex but should be able to see those sections populated if im on my LAN.
The only thing that stands out to me is that I run PMS on a WHS2011 machine and have PlexConnect running on a HTPC,  I don't know if this is a factor or not.
Thanks for any insight you guys may provide.
Regards,
omarti321
Edit:  I did read this thread about having those tabs populated by using external IP or DYNDNS but obviously that is supposed to be outside the lan.
http://forums.plexapp.com/index.php/topic/86031-plexconnect-on-the-go-atv23-no-jailbreak/
-> read before posting.
We need more info: Setup, logs... Settings, did you disable GDM, does GDM detect your server, ...
Sorry, I was at work and not able to get to the logs when I posted.  I didin't change anything except update to the latest release and added the certificate to the assets folder. When I first ran Plexconnect it did not find  the server, so I disabled GDM but it didn't make a difference so I re-enabled it.  I didn't dig to deeply because it worked with myplex.  I just wanted to be certain that I should have items populated in the first 2 tabs.
I'll try to double check and if I can't resolve I will post the logs.
Thanks.
You're probably expected to see what you're seeing if your PMS requires authentication on the local network.
