Updating Plex on QNAP TS-453D
Server Version#: 1.40.2.8395
I have in the last week had to re-install plex onto my NAS for different reasons. When I have installed it from the QNAP app portal and the server and re-synched all of the libaries etc. I am not able to access the liberies. I am getting the message to re-claim the server.
When I try to claim the server I am getting a message to update the server. My question is which package do I need to use when updating the server manually.
The NAS is running on firmware QTS 5.1.6.2722
https://www.plex.tv/media-server-downloads/?cat=nas&plat=qnap#plex-media-server
thanks that is the one I thought it was. I will try again with this package
I have updated the server thank you.
It now not letting my claim the server against my account.
Any ideas on how to solve this issue?
Then we’ll need a zip file with the PMS Logs
Plex Media Server Logs_2024-05-13_15-34-21.zip (5.8 MB)
attached are the logs as requested
Your log shows:
Failed to connect to plex.tv port 443 after 0 ms: Couldn't connect to server
So you need to verify DNS settings as well as the default gateway on your QNAP
thanks how is the best way to do this?
https://docs.qnap.com/operating-system/qts/5.1.x/en-us/configuring-dns-server-settings-A0E9E89C.html
https://docs.qnap.com/operating-system/qts/5.0.x/en-us/configuring-the-system-default-gateway-7541EC49.html
