Updating to plex 1.40.4 synology
Server Version#:1.32.8.7639
Player Version#:synology
@ChuckPa - hi. You helped me rollback my synology after an install to 1.4 went awry. You emailed me three prior versions to slowly upgrade but now I’m pretty far back I think.
Do you think I should upgrade to the synology package update of 1.40.4 or will that be too big of a jump? My DSM is 7.1.1
First, you got some #### going on with “Scrappy”
I don’t know what you were doing but you were on the verge of being completely LOCKED OUT from getting new certificates without one of us resetting your certs.
Side note: I think your friends have some hysterical server names LOLOLOLOL :rofl:
Anyway, back to task.
You’re at 1.32.8.7639 on a DS1618+ ? (C3538 CPU).
You’re not that far behind.
Most of the work being done is transcoding related (which neither of our Syno’s can do! :frowning: )
I am willing to help you get all the way up into the 1.41.x family if you wish.
I’d like to arrange a time to do “The Crossing” with you. (phone + remote desktop).
We’ll make the backups and then push it forward if it’ll go.
Sound like a plan?
Sounds like a plan. You are amazing and def helped me from having to re create everything from scratch.
I am tied up with work calls from 4-5:30est today but available anytime after. I can text you if that helps.
I will be home 7:30-8:00 EST . we can plan around then?
Fire me a text. we’ll get on the phone nd go from there.
Perfect. Ty.
