I upgraded to Version 1.16.1.1246 (beta) and deleted and tried to set up the DVR.
After entering my Canadian postal code (XXXXXX) the DVR setup just stays at 0% and wont advance. So basically the DVR function is not working at all. Tried restarting Plex and i tried restarting the machine. Issue persists.
I have the same issue in the UK, if I enter my real Postal Code, Plex hangs at the same screen as you, I can get it to work by entering codes from nearby to where I live instead, trial and error but some do work. I’d try postcodes near to where you live, and if you live close to a major city try one from there?
I can’t get any postal codes in Ontario Canada to work. I have tried (in the province of Ontario) St Catharines, Niagara Falls, Hamilton, Toronto. However, if i put in a USA zip code (i used Buffalo NY) it works immediately. So what’s the issue with Canadian Postal codes?
