Postal Code not found when installing DVR
My WD PR4100 updated to OS5. I updated both Plex and HD Home Run to OS5. When trying to set up the dvr, plex finds it with no problem (Home Run Quatro) Instally shows how many channels. When I add my Postal code it take me to the “Use an XMLTV guide” page. I click on the “Do not use the XMLTV guide? Click here to use the location guid instead” It has me enter my postal code again and then says “We couldn’t find Plex DVR guide data for your location at this time. Please select a different location or use an XMLTV guide.” I have tryed several different locations and none of the work. I have a windows 11 server and it uses my postal code with no problem. It appears to be a OS5 problem since OS3 worked fine. Any ideas
Have you tried a nearby postal code? It is possible we just don’t have yours in our data but often ones adjacent are the same as far as programming.
