Using new PMS. Same Issue with TV Show Thumbnails missing and not grouping episodes.
@ChuckPa
Rebooted 2 times ran CCleaner and Revo pro Uninstaller… And nuked all in appdata/PMS.
IT WAS COMPLETELY REMOVED! STILL SAME PROBLEM…
On this New Install.. First thing I did was enable logging and set the agents and add ONLY those 3 TV Shows…
Using my C-Name
NEW LOGS (180kb) HERE: ftp://REMOVED
LOGIN= dammit
PASS= janet
Lemme know when ya got it so I can nuke FTP account..
Logs in PMS/ folder
Do not KNOW what else to do! PMS worked fine then this crap all started happening NOW I am PMS-LESS!
PMS… That sounds too much like PMS!
THERE IS NOTHING ON THIS PMS INSTALL!!!
3 SHOWS IS IT!
@ChuckPA
Can you remote it and do your thang maybe?
Really getting frustrated here…
What gives already?
AT @chuckpa @chrisallen WHOEVER?
@OttoKerner can you assist here please?
I am not skilled enough with windows.
Sending you a PM @OttoKerner
Please have at it?? Going on 2 days now…
  1. don’t use Revo uninstaller to remove PMS. It will make your life more complicated.
  2. don’t use CCleaner’s ‘registry optimizer’, it will do more damage than good
  3. your main issue is that your fresh installation of Windows 7 hasn’t gotten updated ‘root certificates’ for encrypted communication (‘TLS’ specifically).
    there is this error in the logs, which is well known:
2018-06-06 17:29:37,720 (c48) :  INFO (logkit:16) - <urlopen error [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:590)>
2018-06-06 17:29:37,720 (3e0) :  INFO (logkit:16) - <urlopen error [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:590)>
I propose, before you are further trying to diagnose Plex, to
  1. update your Windows installation. A fresh installation of Windows 7 needs nowadays several iterations of Windows Update to become fully usable.
    Don’t forget to install “Internet Explorer 11 for Windows 7”, it is updating some crucial system components which are needed.
  2. take a look at this forum thread https://forums.plex.tv/discussion/comment/1534655/#Comment_1534655
    it may provide a short-cut to working posters for tv shows.
Every w7 update is done…
There are no more to get!
Literally… None available
Teamviewer is on… I PM’d you the info…
I DO NOT WANNA FORMAT AGAIN!
I just did and it took a long time as usual to get all the updates, this is a clean install.
@OttoKerner
2) take a look at this forum thread https://forums.plex.tv/discussion/comment/1534655/#Comment_1534655
@OttoKerner
AND THERE IT IS…
It was the Internet 11… I had that uninstalled within Installed components and adding it back fix’erd it right up!
Finally! Before I ripped all my hair out…
Thanks fellas! @ChuckPA @chrisallen @OttoKerner
