Using Plex for help in recovery
Hi folks! I recently found a chunk of audio media just gone. It was totally my fault due to an untested LFTP script. Anyway I spent years building my catalog so I am pretty bummed. Now, II know PMS wasnt the root cause, but hopefully there are bread crumbs, So, the million dollar question is through the older logs, are db file, can i find a reference to the deleted content, where do I look and how. The goal would be to write a SQL query, or simple script to parse the log to help create a list for me so I know what go find.
Thanks all. Best!
If your Plex library hasn’t updated yet (i.e. it still lists tracks that are no longer on your filesystem), you may be able to use WebTools-NG’s FindMedia tool to find differences between what files Plex has registered and what’s on your filesystem. If Plex doesn’t list those tracks anymore, the information might still be in a backup database. If so, the following query would list all file paths in the server, which could then be compared against the file paths that actually exist on your system:
SELECT file FROM media_parts WHERE length(file) > 0 ORDER BY file;
If you wanted to limit it to just music library file paths:
INNER JOIN media_items ON media_parts.media_item_id=media_items.id
INNER JOIN library_sections ON media_items.library_section_id=library_sections.id
WHERE library_sections.section_type=8 AND length(file) > 0 ORDER BY file;
And if you want some basic metadata attached to each track:
SELECT
    sections.name AS Library,
	gitems.title || " - " || pitems.title || " - " || items.`index` || " - " || items.title AS Title,
    parts.file as FilePath
FROM metadata_items items
LEFT OUTER JOIN metadata_items pitems ON items.parent_id=pitems.id
LEFT OUTER JOIN metadata_items gitems ON pitems.parent_id=gitems.id
INNER JOIN media_items media ON media.metadata_item_id=items.id
INNER JOIN media_parts parts ON parts.media_item_id=media.id
INNER JOIN library_sections sections ON items.library_section_id=sections.id
WHERE items.metadata_type=10
ORDER BY Library, gitems.title, pitems.originally_available_at, items.`index` ASC, items.title;
which will output something like
Library Title FilePath
Music Artist1 - Album1 - 1 - Track1 /path/to/track1.mp3
Music Artist1 - Album1 - 2 - Track2 /path/to/track2.flac
It doesn’t do any filtering based on what actually exists on your filesystem, but if you combine it with a script outside of Plex that lists all the files that do exist, you could find what’s different between the two.
This is super helpful thank you. I have 2 mac minis that I need to look through, and to go back further, chromebox, rasberry Pii and intel nuc. I can eliminate the new mac mini, and focus on the older boxes to see what turns up. I will reply back on the weekend.
Again, thank you.
