VC1 direct playback doesn't even start on plex-web
Server Version: 1.20.0.3181 on Windows 10 and a Pentium J5005 with hardware transcoding
Player Version: 4.40.1 on an Surface Pro 3 with Chrome 84
When I try to play any of my VC1 Blu-Ray files, it doesn’t even start the direct playback, although server and Player are connected over a decent 5Ghz local Wi-fi network which should easily reach 400Mbit+ connection speed.
Please tell me if you need more infos and Please help!
VC1 transcodes when using Plex Web, due to browser limitations.
You might try Plex for Windows. It is a more capable client than Plex Web. VC1 & HEVC video both direct play with Plex for Windows.
Hm sorry to come back. If I remember correctly, the video showed at first when starting playing the video “VC1 direct play” (where it didn’t begin to play) before switching to hw transcoding after a while and then playing okay…
I can also confirm this exact problem, I noticed it last week. It happens to me with Intel Quick Sync with PMS Beta and PlexWeb, and I believe only with VC-1 so far.
The same PMS successfully transcodes VC-1 for the Roku, though.
I can test later tonight to see if it’s still happening, since I haven’t tested the problem since last week.
Some more detail:
This happens with Edge (Chrome version).
Hardware transcoding to PlexWeb worked properly with:
  • Kaby Lake i5, PMS (stable version on Windows 10), using QSV.
  • Quadro P400, PMS (beta version on Windows 10), using NVENC
And it failed with:
  • Celeron J4005 PMS (beta version on Windows 10), using QSV. It never starts, and the status in PMS stays as Direct Play until I give up (it’s possible it works eventually, but it was a long wait).
VC-1 used to transcode on the J4005, so this is a change in functionality. Could this be a problem with how Plex is working with the Goldmont CPU/GPU line?
PMS 1.20.0.3181 on Synology DS918+ (Celeron J3455)
Plex Web 4.40.1 (app.plex.tv)
Chrome 84.0.4147.125 64-bit on Win10 Pro 2004
Edge/Chrome 84.0.522.59 64-bit on Win10 Pro 2004
I played several VC1 1080p Blu-ray rips using both browsers on same PC. No problems. The video started right away and used hardware transcoding.
So maybe an issue with PMS, Win10, QSV, & Gemini Lake processors?
