Hi, I’m having issues watching 1080p BluRay rips that are in VC1 format if hardware transcoding is on.
Video plays for a couple of seconds, then buffers, then plays some more etc. CPU usage is about 25%
If hardware decoding is off, it plays fine, CPU usage is about 75%
No problems with BluRay rips in other codecs - same 25% usage with hardware decoding on and no buffering issues.
Thanks for the tip - I didn’t realise 1.11 was a beta release.
After downgrading a situation I described has somewhat improved.
On a beta I couldn’t get a smooth playback with any quality settings with hardware transcode enabled. And now with 1.10 I can lower it down to a little disappointing 3Mbps 720p to get buffering free playback.
Still this looks strange to me that my NAS that is capable of smooth software encoding with 75% CPU load might be struggling with hardware enabled task while being used only in the range of 25-30%…
VC-1 has not enabled for hardware transcoding by engineering yet.
That’s good to know, but still what I can’t understand is this:
Hardware transcoding off: VC-1 video is being played back smoothly, without buffering, CPU at 75% load
Hardware transcoding on: VC-1 video is interrupted with buffering, CPU at 25-30% load
It looks like a bug to me, I can’t find any logical explanation to this…
ChuckPA, I hope I’ve prepared the requested info correctly:
Here’s a link to a sample (1m 40s, appr. 300Mb): dropbox.com/s/vh5q9pmz3l7dtig/plex_issue_demo_file.mkv?dl=0
Two sets of logs are attached to this message (both demonstrating playback of the same 1m 40s)
Thank you for them but no playback activty shows. If you look, there is only a few Kilobytes in each. There should be 200-300 KB in each.
Can you recreate it again?
Also, between those times you purge the logs, Please remember to perform a proper PMS shutdown. It will give me the full picture by flushing all the buffers to disk
I have a similar issue when converting from MPEG2 (software) to H264 (HW). I’m convinced that when Plex has HW transcoding enabled, it is only using a single core for both tasks. Until they work this out, I’ve just disabled HW transcoding.
I can confirm the same issue on a Synology 918+ running 1.11.0.4666.
VC-1 Video, Dolby 5.1 PCM audio. With hardware transcode on, video studders to the point of being unplayable. With transcode off, video transcodes/plays fine.
Video behavior is the same regardless of wether the audio is being transcoded. I also tried on a VC-1/DTS-MA HD.
I have a DS418Play, which I believe suffers from the same thing. (VC-1 HW transcode not supported) I’ve Optimized all my VC1 MKVs to h.264 versions in the interim. Any news on when this will be resolved? (DS418 play has the Apollo Lake CPU (Intel Celeron J3355))
Plex doesn’t give roadmaps or schedules. (just how they do things).
I can tell you I see all the chatter about VC-1. I don’t have any hard details.
Re the DS418play, make certain you do bump up the memory. That seems to be important for those doing HEVC. I suspect VC-1 will have a similar relationship
Just wanted to circle back with @ChuckPa to see if any progress had been made towards HW support for VC-1. Anything you can share would be greatly appreciated!
