Version 1.14.1.5448 stuck on "Checking for updates"
Server Version#:1.14.1.5448
Player Version#:3.91.0
Hello,
I am aware that there is an update to 1.15.x for my ReadyNas version of Plex, however my GUI is stuck at “checking for updates”. If I download the newest version, it warns that it will uninstall the current version and install fresh. Is there a way to unlock the “checking for updates” to retrieve the updates, or upload manually without erasing everything?
Logs are attachedPlex Media Server Logs_2019-03-18_13-16-26.zip (2.5 MB)
Thanks,
-Erik
Mine is stuck exactly the same on Windows 10
Plex Media Server 1.15.1.791 is now available to everyone
Note: Auto-update will be disabled for a few days. In the meantime, you can grab the new version from our Downloads page .
Appreciate the link, however, if I use the download, it wants to install fresh versus updating which is not the desired affect.
That may be why they disabled auto update…
I’t may need to rebuild or modify the database, How ever since I have not loaded it I can just speculate. I usually wait a few weeks after a build is released to the general public to see what bugs are found…
