FIXED:
Media Remote play/pause buttons not working in video player when OSD is hidden
The play/pause media remote button issue is not actually fixed in the new version. The play button now toggles between the playing/paused state, but the pause button does nothing. It’s a step in the right direction at least.
All universal remotes will have separate play and pause buttons. I’m using the Harmony remote. For me, play or pause worked as separate buttons before this latest update. If the devs are mapping specifically to the Xbox one remote I don’t think that will satisfy the requirement. It should map to standard play and pause buttons.
I’m using a Harmony One, and always have been. I have the play and pause buttons sending the appropriate commands. There are three different commands you have to handle. In the normal windows SDK they are
