Vertical subtitle position options
Hi! Could you please add a way to choose the vertical position of the subtitles, as well as font, color, and boldness? I have tunnel vision and can only focus on one area of the screen at once, and it helps if its high contrast. Thanks!
On what particular app are you missing this option?
e.g. Plex for Android TV, HTPC and the iOS apps should already allow that.
https://support.plex.tv/articles/settings-android-tv/
https://support.plex.tv/articles/htpc-settings/
https://support.plex.tv/articles/205671068-settings-plex-for-ios/
Plex Web also has an option to specify the vertical subtitle position (though it’s not specifically mentioned in the support articles (Settings > Plex Web > Player > Subtitle Position) – same for the regular desktop app.
There’s been an existing suggestion asking for similar support in different other platforms – as well as an option to configure font, colors etc. You might want to comment/vote in that thread in order to help us avoid distracting or cannibalizing votes.
