Video File with both Dolby Vision and HDR10+ reverts to hdr10 on samsung tv plex client
I am playing back a video file which supports both DoVi and HDR10+ on my samsung tv plex client (qn90c 50 inch), For some reason, the player reverts to hdr10 rather than hdr10+
If i strip out the dolby vision metadata using an external tool, it plays properly in hdr10+. Is the plex client at fault here?
Below is the mediainfo output if it helps
General
Unique ID : 184507356005099234338117189951692452539 (0x8ACED2FE0CC588AB9E9AA2D92D27B2BB)
Complete name : Movie.MKV
Format : Matroska
Format version : Version 4
File size : 6.43 GiB
Duration : 58 min 8 s
Overall bit rate : 15.8 Mb/s
Frame rate : 24.000 FPS
Writing application : mkvmerge v82.0 (‘I’m The President’) 64-bit
Writing library : libebml v1.4.5 + libmatroska v1.7.1
Video
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main 10@L5.1@Main
HDR format : Dolby Vision, Version 1.0, Profile 8.1, dvhe.08.06, BL+RPU, no metadata compression, HDR10 compatible / SMPTE ST 2094 App 4, Version HDR10+ Profile A, HDR10+ Profile A compatible
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 15.2 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Color space : YUV
Chroma subsampling : 4:2:0 (Type 2)
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.077
Stream size : 6.19 GiB (96%)
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
Mastering display color primaries : Display P3
Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 741 cd/m2
Maximum Frame-Average Light Level : 121 cd/m2
Audio
Format : E-AC-3
Format/Info : Enhanced AC-3
Commercial name : Dolby Digital Plus
Codec ID : A_EAC3
Bit rate mode : Constant
Bit rate : 256 kb/s
Channel(s) : 6 channels
Channel layout : L R C LFE Ls Rs
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Stream size : 106 MiB (2%)
Language : English
Service kind : Complete Main
Default : Yes
Forced : No
Dialog Normalization : -25 dB
compr : -0.28 dB
dmixmod : 3
ltrtcmixlev : -3.0 dB
ltrtsurmixlev : -3.0 dB
lorocmixlev : -3.0 dB
lorosurmixlev : -3.0 dB
dialnorm_Average : -25 dB
dialnorm_Minimum : -25 dB
dialnorm_Maximum : -25 dB
Text
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Title : English [SDH]
Language : English
Default : No
Forced : No
I have the same issue.
