How do you create a video playlist on PLEX?
I create my video playlists in Plex Web. Find the video you want to add to a playlist then click the ‘add to playlist’ button on the left menu, then you can add the video to an existing playlist or create a new playlist. You can also add an entire TV series or season by selecting the 3 dot menu and select ‘add to playlist’ from the menu.
Thanks for that. I don’t even know what Plex Web is but I’m going to look into it and follow your advice. Thanks again.
Plex Web is the main web interface you use with your Plex Media Server.
