Videos H264 keep buffering remotely
Could someone help me in providing a solution for the problem that I am facing? When I try to watch any H264 videos remotely the videos just keep buffering, I have connected my Plex server on NAS EX4100 WD with internet speed 260 MB/s. Also, I have kept the option on Plex “Background transcoding x264 preset” to ultra-fast to help me in buffering, however, I am still facing a buffer problem.
Any help, please :slight_smile:
Is that 260 Mbps your internet upload or download speed? If it’s the download speed… what’s the upload speed you get from your ISP?
In addition… can you double-check the Now Playing section of the Dashboard in Plex Web to confirm how the media is transferred (remote vs. indirect) and if/how it’s being transcoded. Maybe you can attach a screenshot of that tile.
here is my network speed that is connected to my NAS.
please note that some series works flawlessly. However, some series keeps buffering; this only outside my home network. in the same network all videos runs perfectly
Looks like that particular video is transcoding heavily (near 100% CPU consumption).
Could you for completeness provide the screenshot of the particular ´now playing element. In particular:
  • is it showing as remote or indirect playback?
  • which parts of the video is causing the transcoding?
It looks like that’s not actually a h264 video but h265/HEVC.
The WD cannot hw-transcode that format, so it’ll do it all with its CPU which appears not to be strong enough to do that in real-time.
You could try to set the playback quality to “original” or “max” on your iPhone to avoid the transcoding (in Plex for iOS on your iPhone: Settings > Quality > Remote Streaming). That might work if you’re mobile bandwidth and/or data plan don’t get in the way :wink:
Edit:
not really changing the statement above… the EX4100 has no support for hw-transcoding at all (that’s the MyCloud Home and MyCloud Pro models). Nonetheless… transcoding h265/HEVC is too much for that NAS
image image
Still the same …
So what is the best type of videos i need to look for. I am sorry for these kinds of questions, I am new in this field :slight_smile:
Or how do I know which type of videos suits my NAS
The simple answer are the ones that don’t transcode
How do I know that, is there any way I can know that before downloading a video/movie?
Safe bet is mp4, but they can have pitfalls with embedded metadata. I use mkv mostly
One of the series that i am facing a problem in buffering is .mkv
does the size matter of the video matter?
SE56’s post was a little misleading…
MP4 (or M4V) as a file container will be the most compatible.
What’s more critical is what is inside that container.
In your case that’s a h264 video with aac audio. Those codecs are among the most safe ones with todays players. The bitrate could be a limiting factor that can cause Plex to decrease the quality.
If the file content is ok to play in the client without transcoding, Plex will be able to “re-mux” the files – meaning it’ll just put the content in a different container on-the-fly.
To determine what is causing the buffering we’d need to dig into your logs.
please if you can help i will share with you the log. I just want to understand the types of videos that support my NAS
Or how i can convert the videos to have the same quality and it can work on my NAS? i think this way it will be easier for me to do
Mind sharing those logs?
The Plex app on iOS should actually play a lot natively and directly without transcoding if you…
  • use the new player (default by now; some users still opt to disable it)
  • avoid settings in the client that require transcoding; check the following client settings:
    • Settings > Quality > Remote streaming (see above)
    • Settings > Advanced > Allow Direct Play (should be checked)
    • Settings > Advanced > Use old player (should be disabled)
    • Settings > Advanced > Subtitles > Burn subtitles (should be set to automatic)
  • avoid settings in the server that cause transcoding; e.g.
    • Settings > [Server Name] > Remote Access > Internet upload speed
    • Settings > [Server Name] > Remote Access > Limit remote stream bitrate
    • Settings > [Server Name] > Network > Remote streams allowed per user (should only impact your playback if you play videos from multiple clients simultaneously)
    • Settings > [Server Name] > Transcoder > Maximum simultaneous transcodes (should only impact your playback if you play videos from multiple clients simultaneously)
From the screenshot above this video should play ok.
Screenshot_4 Screenshot_5 Screenshot_6
