View progress bar with Harmony remote without pausing
I’m trying to figure out a way to view the progress bar without having to pause the content I’m watching. Using the Xbox One controller, it’s mapped to RB (Right Bumper) but this is not an input that can be sent from a Harmony remote - it’s not even on the Xbox Media Remote, so I’ve got to imagine it’s not an input that is accepted via IR.
Is there any other way to view the progress bar?
Currently the View button on the controller is unused in the Plex app, and this is a command that can be sent via IR. Presuming that there is no way to view the progress bar as described above, I suggest the View button be mapped to do so. Logistically I think it makes sense anyway.
Press ‘A’ on the controller or the ‘OK’-Button on the official media remote (in the middle of left/right/up/down) and the progress bar will light up for 5 seconds.
I am a little confused about the RB or you not finding a button on the media remote, as this is indeed working.
Maybe a bug? - Or did you change any buttons in the xbox controller accessory app?
On my harmony, I press ‘ok’ and it shows the progress bar.
I’m not really sure how I didn’t see the OK button doing it. I thought the A button on the controller paused it, not just showed the progress bar, but I see now you’re right. RB and LB on the controller also do it. Thanks!
