Viewing 4K HDR on Plex app for Samsung
Server Version#: 1.28.2.6151
Player Version#: 4.87.2 (From PLEX WEB/General…)?
This is the information for the PLEX app on my Samsung TV:
  • Updated: 8/23/2022
  • Latest Version: 5.32.1
I recently upgraded to a Plex plus account, so I could view 4K HDR the way it’s supposed to be viewed. However I cannot find any documentation for settings for my Plex TV app with regard to 4K HDR. I’ve seen YouTube videos, like whether to transcode or not to transcode, etc. Frankly, they usually are over my head. I’ve attached a screenshot of my settings on the computer app under transcoder.
I do not see very much documentation on Plex support for settings on the TV apps. Basically, I’m always at a loss as to what the setting should be. For instance, for 4K HDR, should I allow direct stream? Should I allow direct play? When I have those selected, the picture looks muddy. When I don’t have them selected, the picture looks better but it buffers every 2 to 3 minutes. Also, what does “Disable bitrate limiting” mean. I usually leave that checked.
I’ve also included a screenshot of my Macintosh system, which is fairly robust.
Thanks in advance for any help anyone can give me!
*Frankly one of the reasons I upgraded to Plex+ was because I thought it came with actual support, but much to my dismay it’s still only community forums. No offense to the community! LOL!
There is no need to upgrade to a Plex Pass just to watch 4K HDR.
Correction: You do not need a Plex Pass when direct playing 4K HDR media. However, direct playing is not always possible. Plex sometimes has to transcode 4K HDR media. When this happens, tonemapping is required to display correct colors. HDR to SDR Tonemapping requires a Plex Pass. Ideally, you’ll never need tonmapping, but it will occur on occasion. See posts below for additional details.
There are no 4K HDR specific settings in the Samsung app.
Enable Direct Play and Direct Stream in the Plex app on the Samsung. They should be enabled by default.
You will need to avoid subtitles when playing media with TrueHD or DTS audio. With the Plex Samsung app, enabling subtitles with either of those formats results in a video transcode (*).
You want to avoid transcoding. If Plex is transcoding, then you are watching SDR, not HDR, video.
You can monitor playback via Plex Dashboard → Now Playing.
(*) Current Samsung (and LG) TVs do not support TrueHD or DTS audio. Therefore, Plex must transcode them to a supported format. With the Plex Samsung (and LG) app, transcoded audio + subtitles results in a video transcode. The output of the Plex video transcoder is SDR, not HDR, video. So you’ll want to avoid transcoding HDR video whenever possible.
Thanks, Ford…
The first time I viewed a 4K HDR movie on my Samsung Plex app, it looked really “muddy.”
Also, I got a notice via the Samsung app that said something like for optimum viewing you needed HDR tone mapping, which is only available with a Plex plus account, so I got the free month trial.
So it turns out I do not need HDR tone mapping via the Plex plus account at all? Just turn off transcoding.
So when I turned off transcoding, the picture looks great.
I suppose that was just Plex’s misleading method for getting people to pay for a Plex+ account.
Glad I didn’t pay for a sub.
PS: Galadriel sure looks good in 4K!
I forgot HDR Tonemapping was a Plex Pass only feature. Ideally you will not need it, but sometimes it is necessary.
You want to direct play media whenever possible, especially 4K HDR. When direct playing, Plex Media Server sends the media to the client (i.e. Plex app) unaltered.
Plex sometimes has to repackage the video/audio/subtitle streams. This is generally referred to as remuxing. Plex also calls it Direct Streaming. This can happen for several reasons. One common reason is when the media contains an audio track not supported by the client. Plex transcodes the audio to a supported format, then repackages it with the video & subtitles and sends it to the Plex client.
If Plex cannot direct play or direct stream the video, it will transcode it. Most of the time this is not too much of a problem. However, 4K HDR is a special case. The output of the Plex video transcoder is always SDR video. Also, to make the colors look correct, the Plex server must tonemap the HDR to SDR colors. Otherwise, the colors look “off” or “washed out.”
This is where you start to run into the limitations of the Plex Smart TV apps. It is easy to inadvertently trigger a video transcode and suddenly you are watching SDR video. It still looks good (as long as it is tonemapped), but it isn’t as good as HDR video.
With the Plex Samsung app, if Plex is Direct Playing, enabling subtitles is not a problem.
However, if Plex is Direct Streaming, enabling subtitles results in a video transcode, which means you’re watching SDR, not HDR, video.
As mentioned earlier, Samsung does not support TrueHD or DTS audio formats. When you play a file with those formats, they will be transcoded by Plex Media Server to a supported format. Plex will recombine the video and audio and direct stream it to the Plex app. This is all OK. You will get HDR video and transcoded audio.
The problem arises when you enable subtitles. Direct Streaming + subtitles results in a video transcode. Then you are watching tonemapped SDR video instead of HDR video.
That is why I mentioned avoiding subtitles when playing a TrueHD or DTS audio track.
Blu-ray movies with TrueHD audio also have a Dolby Digital audio track. If available, play the Dolby Digital audio track instead, as it will direct play.
Unfortunately, movies with DTS audio generally do not include a Dolby Digital audio track. Therefore when playing DTS audio, do not enable subtitles or the video will transcode.
To condense all of the above into four lines:
  • Dolby Digital + Subtitles = OK
  • Dolby Digital Plus + Subtitles = OK
  • TrueHD + Subtitles = video transcode
  • DTS + Subtitles = video transcode
I hope I’ve explained things clearly and not confused you. Unfortunately, the issue with subtitles is not in the Plex documentation. Most people run into it and don’t understand what is happening.
As far as the Plex Pass goes, it is good you have it so you can tonemap when needed. I’ll correct my earlier post.
Wow thanks man!
You really know your stuff when it comes to Plex. I on the other hand do not, but I can learn, even at my decrepit age. I know I’m not supposed to tag on another question to a post, but I am going to post a question I’ve been dying to get an answer to. I would love it if you could keep an eye open for it. It’s regarding sharing my video library with friends.
Thanks again, Dude—your help is greatly appreciated!
I have 3 Samsung Smart TVs. I have a 40UJ6400 (2015), a 55Q90T (2020), and a 55QN95A (2021). I also have many 4K movies on my NAS. The UJ6400 and Q90T play flawlesly the 4K content, while QN95A doesn’t like 4k, with few exceptions. The version of plex is the same on Q90T and QN95A, but the Plex doesn’t work the same, unfortunately. All 3 tvs are wifi conected to NAS. Why so different behavior of Plex?
Playing 4k content through internal samsung player is ok, except DTS encoding.
Samsung 2021 tv’s have issues. The information is scattered on the forums. Here is one post:
Fordguy made another recently that’s detailed but I lost track of it.
Thanks to all.
Oddly enough, the issue I’m having is that, for example, the new Lord of the Rings series looks smashing on my Samsung TV (UN65TU7000FXZA). However, the new Game of Thrones series looks like crap. They are both “4K HDR10 (HEVC Main 10).”
Go figure.
