I have installed 5 folders containg film series into Plex.
The setup of all 5 folders are exactly the same as each other.
I created a library and sent all 5 over.
When I go to Plex only 4 x folders are coming thru?
Sorry I don’t know what that means. You created 1 library from the 5 folders, or do you have 5 different libraries with 1 folder each?
Are you sure permissions are all the same
FAQ 19: Setting permissions to allow Plex access to media files
Before beginning, it’s important to remember one key point; Plex doesn’t have any special privileges on Synology except for being able to access the Video Transcoding acceleration hardware. It cannot read any of your files unless you expressly grant permission. This is a fundamental principle of Linux (which Synology uses for DSM)
Because of how Synology grants permission, access to files is broken into two different …
Thank you so very much for your help. Regards Stuart
Still a problem I cant resolve.
system
Closed
February 24, 2021, 7:50pm
9
