Player Version: 9.19.1.525
Hi, there’s a small visual bug on AndroidTV devices regarding the playback indicator or whatever you call the white round indicator on the playback timeline. ![]()
The player UI, specifically the playback timeline, seems to have issues with focus when you start/access a video from the library. As soon as you open a video, the UI focuses on both the play/pause icon AND the playback timeline - hence the white bubble is displayed every time when it should not be [pic 1].
If you then manually focus the timeline (i.e., fast-forward through the video) [pic 2] and close/hide the player UI, the next time you view it, the focus correctly appears to be only on the play/pause button [pic 3].
I’m sorry if this all sounds rather complicated, but in reality it’s actually not. I’m just unsure how to describe this visual error correctly.
Thanks!
