Log from terminal is is below, Went to play a movie this morning, the trailers show all the movies, selected one hit play, get the revolving wheel for what seems to be a long time then nothing but a blank screen. Up to this point everything has worked flawlessly. I have not installed any programs. Even rebooted the iMac, made sure the plexserver was up and running prior to executing the plexconnect in the terminal window. Obviously I must have done something but am at a loss to know where to go to attempt to fix. Note: if I quit ATV3 and connect via a windows PC running plex client that same movie plays just fine. Could really use some help.
More info:
DNS on ATV3 is 192.168.1.131
IP on imac (Plex Server and PlexConnect running here: 192.168.1.131
Imac running ML 10.8.4
Media on a drive connected to the iMac
Uncertain of Plexconnect version, files in folder indicate June 18th 12:45 pm
settings cfg info:
[PlexConnect]
port_pms = 32400
enable_plexgdm = True
ip_dnsmaster = 8.8.8.8
ip_webserver = 0.0.0.0
loglevel = Normal
enable_dnsserver = True
ip_pms = 192.168.178.10
port_webserver = 80
Log:
Last login: Sat Jun 22 07:18:26 on console
Matts-iMac:~ iMacmcs$ cd /Users/iMacmcs/Downloads/PlexConnect-XML_templates
Matts-iMac:PlexConnect-XML_templates iMacmcs$ sudo ./Plexconnect.py
Password:
07:23:34 PlexConnect: started: 07:23:34
07:23:34 PlexConnect: ***
07:23:34 PlexConnect: PlexConnect
07:23:34 PlexConnect: Press ENTER to shut down.
07:23:34 PlexConnect: IP_self: 192.168.1.131
07:23:34 PlexGDM: ***
07:23:34 PlexGDM: looking up Plex Media Server
07:23:35 PlexGDM: servers discovered: 1
07:23:35 PlexConnect: PMS: 192.168.1.131:32400
07:23:35 DNSServer: started: 07:23:35
07:23:35 DNSServer: ***
07:23:35 DNSServer: Starting up.
07:23:35 DNSServer: intercept trailers.apple.com: 192.168.1.131
07:23:35 DNSServer: forward other to higher level DNS: 8.8.8.8
07:23:35 WebServer: started: 07:23:35
07:23:35 WebServer: ***
07:23:35 WebServer: WebServer: Serving HTTP on 0.0.0.0 port 80.
07:33:57 DNSServer: DNS request received!
07:33:57 DNSServer: Source: ('192.168.1.100', 58859)
07:33:57 DNSServer: Domain: ax.init-cdn.itunes.apple.com.akadns.net
07:33:57 DNSServer: ***forward request
07:33:57 DNSServer: -> DNS response from higher level
07:36:19 DNSServer: DNS request received!
07:36:19 DNSServer: Source: ('192.168.1.100', 60086)
07:36:19 DNSServer: Domain: trailers.apple.com
07:36:19 DNSServer: ***intercept request
07:36:19 DNSServer: -> DNS response: 192.168.1.131
07:36:20 DNSServer: DNS request received!
07:36:20 DNSServer: Source: ('192.168.1.100', 60086)
07:36:20 DNSServer: Domain: trailers.apple.com
07:36:20 DNSServer: ***intercept request
07:36:20 DNSServer: -> DNS response: 192.168.1.131
07:36:20 WebServer: serving application.js
07:36:21 WebServer: serving /Users/iMacmcs/Downloads/PlexConnect-XML_templates/assets/plexconnect.xml
07:36:21 WebServer: serving /Users/iMacmcs/Downloads/PlexConnect-XML_templates/assets/utils.js
07:36:21 ATVLogger: loadItem: Library
07:36:21 WebServer: serving .xml: /library/sections
07:36:25 WebServer: serving .xml: /library/sections/3
07:36:25 WebServer: serving /Users/iMacmcs/Downloads/PlexConnect-XML_templates/assets/utils.js
07:36:27 WebServer: serving .xml: /library/sections/3/all
07:36:29 WebServer: serving /Users/iMacmcs/Downloads/PlexConnect-XML_templates/assets/utils.js
07:36:29 WebServer: serving /Users/iMacmcs/Downloads/PlexConnect-XML_templates/assets/scrobble.js
07:36:34 WebServer: serving .xml: /library/metadata/875
07:36:36 WebServer: serving /Users/iMacmcs/Downloads/PlexConnect-XML_templates/assets/utils.js
07:36:36 WebServer: serving /Users/iMacmcs/Downloads/PlexConnect-XML_templates/assets/selectAudioAndSubs.js
07:36:38 WebServer: serving .xml: /library/metadata/875
07:36:38 ATVLogger: Player state: Loading at this time: 0
07:38:06 DNSServer: DNS request received!
07:38:06 DNSServer: Source: ('192.168.1.100', 60015)
07:38:06 DNSServer: Domain: trailers.apple.com
07:38:06 DNSServer: ***intercept request
07:38:06 DNSServer: -> DNS response: 192.168.1.131
07:38:06 ATVLogger: Player state: Playing at this time: 2108
07:38:20 ATVLogger: Player state: Paused at this time: 2120.850554013
07:38:26 ATVLogger: Player state: Loading at this time: 2111.097
07:38:33 ATVLogger: Player state: FastForwarding at this time: 2111.097
07:38:36 ATVLogger: Player state: Loading at this time: 2119.097
07:38:47 ATVLogger: Player state: Rewinding at this time: 2119.097
07:39:23 DNSServer: DNS request received!
07:39:23 DNSServer: Source: ('192.168.1.100', 51752)
07:39:23 DNSServer: Domain: trailers.apple.com
07:39:23 DNSServer: ***intercept request
07:39:23 DNSServer: -> DNS response: 192.168.1.131
07:39:23 ATVLogger: Player state: Loading at this time: 0
07:39:52 ATVLogger: Player state: Rewinding at this time: 0
07:39:53 ATVLogger: Player state: Loading at this time: 0
07:40:13 ATVLogger: Player state: Rewinding at this time: 0
07:40:13 ATVLogger: Player state: Loading at this time: 0
07:40:58 DNSServer: DNS request received!
07:40:58 DNSServer: Source: ('192.168.1.100', 55802)
07:40:58 DNSServer: Domain: trailers.apple.com
07:40:58 DNSServer: ***intercept request
07:40:58 DNSServer: -> DNS response: 192.168.1.131
07:40:58 ATVLogger: Player state: Stopped at this time: 0
07:40:59 WebServer: serving .xml: /library/metadata/875
07:40:59 WebServer: serving /Users/iMacmcs/Downloads/PlexConnect-XML_templates/assets/utils.js
07:40:59 WebServer: serving /Users/iMacmcs/Downloads/PlexConnect-XML_templates/assets/selectAudioAndSubs.js
07:41:07 WebServer: serving .xml: /library/sections/3/genre/71?X-Plex-Container-Start=0&X-Plex-Container-Size=50
07:41:08 WebServer: serving /Users/iMacmcs/Downloads/PlexConnect-XML_templates/assets/utils.js
07:41:12 WebServer: serving .xml: /library/metadata/875
07:41:12 WebServer: serving /Users/iMacmcs/Downloads/PlexConnect-XML_templates/assets/utils.js
07:41:12 WebServer: serving /Users/iMacmcs/Downloads/PlexConnect-XML_templates/assets/selectAudioAndSubs.js
07:41:17 WebServer: serving .xml: /library/metadata/875
07:41:17 ATVLogger: Player state: Loading at this time: 0
07:42:42 DNSServer: DNS request received!
07:42:42 DNSServer: Source: ('192.168.1.100', 49171)
07:42:42 DNSServer: Domain: trailers.apple.com
07:42:42 DNSServer: ***intercept request
07:42:42 DNSServer: -> DNS response: 192.168.1.131
07:42:42 ATVLogger: Player state: Playing at this time: 2108
