Watch progression not being tracked
Server Version#: 1.41.3.9314
Player Version#: all players
watch progression is not being tracked for shows and movies since last update. i will watch several episodes of a show and then i will come back to the show later and it never marked the shows that i watched as watched. when i manually mark it it still does not work. i have tried on several platforms and same behavior.
this server is installed on an unraid 6.12.10 using the liuxserv.io container
Linuxserver.io version: 1.41.3.9314-a0bfb8370-ls251
Build-date: 2025-01-01T22:46:32+00:00
I am sorry not really sure how to get the logs other than this from the unraid side of things
[migrations] started
[migrations] no migrations found
usermod: no changes
Brought to you by linuxserver.io
To support LSIO projects visit:
https://www.linuxserver.io/donate/
GID/UID
User UID: 99
User GID: 100
**** Server already claimed ****
Docker is used for versioning skip update check
[custom-init] No custom files found, skipping…
Starting Plex Media Server. . . (you can ignore the libusb_init error)
[ls.io-init] done.
Critical: libusb_init failed
You might want to check your database for corruption.
Thank you for your reply. I have checked the database using the built-in integrity checker and it has come back just saying OK so I’m not sure where else to go from here. I may try to upgrade unread to 7.0 and see if that fixes the problem.
