Hi guys,
I was wondering if there is any solution to index properly wav files.
I saw somewhere instructions for an album but my collection is 95% compilations.
All the compilations are by Various Artists so the album artist is VA but each song’s artists is different.
Any suggestions ?
Igor
Do you mean:
- every track is a separate wav file or do you mean
- each CD is one continuous wav file ?
- will never work in Plex
For 1) you must either follow this guide to the letter:
https://support.plex.tv/articles/200265296-adding-music-media-from-folders/
Or this one:
Then you can add the cover art and lyrics like this:
However, in my personal opinion, you are better off if you convert these tracks to Flac format. This will not only save about 35% of space, but also add the ability to insert meta tags into the files. All that while retaining the full quality of the files.
all my albums are in folders like this :
VA - Top Pop 93 Vol. 1 <-- Folder
01 - 2 Brothers on the 4th Floor - Never Alone.wav <— File
02 - 2 Unlimited - No Limit (Rap Radio Version).wav <— File
they are all “VA - Compilation Name”, sometimes there are 2 CDs - I would love to find out how to make Plex recognize the 2CD layout …
Please click on my links above. It is all explained in there and I have already managed to get multi-cd albums into plex using this method.
So for WAV files i need the following structure ? Did I get you right ?
Music /
Various Artists /
Various Artists - Top Pop 93 Vol. 1 /
I need the master “Various Artists” folder and again “Various Artists - Compilation Name” folder inside the master one ?
For single-disc compilations:
Music /
Various Artists /
01. 2 Brothers on the 4th Floor - Never Alone.wav
02. 2 Unlimited - No Limit (Rap Radio Version).wav
for multi-disc compilations:
Music /
Various Artists /
Disc 1 /
Disc 2 /
01. track artist - track title.wav
02. track artist - track title.wav
After changing those file or folder names, you need to perform the Plex Dance
(step 4 of the dance can be omitted with music)
But, a mentioned above, you are better off converting those files to FLAC format.
Thank you !
Is the title of the album really just ‘Volume 1’?
Settings - Server - Agents - Albums - last.fm
Make sure that the line ‘Local Media Assets’ is in the topmost position.
Do also this:
edit your music library,
go to the ‘Advanced’ tab and
check ‘Use embedded tags’
After making these two changes, repeat the Plex Dance.
Still i do not get album names and double cds appearing as 2 separate ones …
Which folder did you add to the library?
It should be C:\Music, nothing else.
(properties of the library, ‘Add Folders’ tab)
Of course … C:\Music
I’m giving up on WAVs …
I’ll convert everything to Flac and that’s it
Any chance Plex will ever support WAV oob or maybe there is a way to inject metadata into WAV files as well ?
There is, but Plex doesn’t support this type of metadata.
Just like 97% of all other software which accepts wav files as input.
Too bad.
Well thanks anyway.
Now with flac everything is working except the 2cd discs. I built the folder with “Disc 1” and “Disc 2” subfolders and the Metadata on the flacs is “AlbumName - Disc 1” on the first and “AlbumName - Disc 2” on the second but nonetheless Plex recognizes 2 albums with the same artwork.
This is the mistake. The ‘album title’ meta tag must be identical for all tracks in an album. Otherwise you’ll get 2 albums in Plex.
There is a separate meta tag for the disc number.
Edit the tags and then repeat the Plex Dance.
