WebOs Plex share
Server Version#:
My LG C9 is not able to access plex share, I can access it on mobile and laptop, not sure what is wrong
If you’re using a TV with an older version of WebOS (pre WebOS 5.0) your issue might be linked to this announcement:
Thanks, but any idea how to fix this my webos version is 4.9.3
There’s a description in the announcement.
If you cannot upgrade your version of WebOS you’ll need to set secure connections for your server to “disabled” in order for the WebOS Plex app to remain able to see your server.
Start calling your LG and report the issue. It is LG OS have outdate letencrypt root cert certificate
I own an LG that has WebOS 5.40 and still having the same issues. Strange…
Luckily I found this thread and enabled insecure connections so I can get back to my daily routine.
Thanks!
