weird hebrew subtitle problem.
i have srt of an episode and at some point, by translator mistake in the subtitle you see the timing. from that point and on no subtitle in the episode. how is it ? there is still timing and everything but by mistake in one line some numbers.
how does is happen ?
Only on aTV/PlexConnect? Did you check other clients?
To me, this sounds like a "How to fix an SRT?" or a PMS ("How to decode SRT?") question.
didn't check on other clients but the srt is fine.
in some line, theres it's timing in the line but the real timing is in and is should show mw the timing and it doesn't and nothing after that. i fixed that but how pms/plexconnect decided to stop showing subtitles only cause there were numbers in the line, that is my question
Sorry, but PlexConnect doesn't show subtitles on its own.
It's either PMS transcoding the text into the video stream or the native aTV videoplayer.
I guess, you have to get more details and/or - if it's and PMS issue - check in the PMS forums.
if it was the native tav video player hebrew subtitles was perfect cause the native atv videp player supports them ..
