I found that automatic downloads of subtitles from opensubtitles has broken… although I refresh the metadata of themovie and themovies subititles exists inside the opensubtitles.org, Plex can not get the subtitle.
Since many years settings agents opensubtitles always ticked! usernamepassword always there…
but since some time 2 or 3 monts no any autodownload of movie subtitles. currently event I change my username and password … nothing happens…
in the logs it is always says (even username and passowrds are wrong)
2020-07-04 03:02:14,975 (7fdf82ffd700) : DEBUG (networking:143) - Requesting ‘http://127.0.0.1:32400/library/metadata/227676/tree’
2020-07-04 03:02:14,977 (7fdf82ffd700) : INFO (init:53) - Existing token found. Revalidating.
2020-07-04 03:02:15,147 (7fdf82ffd700) : INFO (init:76) - Valid token.
2020-07-04 03:02:15,147 (7fdf82ffd700) : INFO (init:116) - Looking for match for GUID d6a208982fc59055 and size 8527988908
2020-07-04 03:02:15,220 (7fdf82ffd700) : INFO (init:126) - Found nothing via hash, trying search with imdbID: 2066051
2020-07-04 03:02:15,302 (7fdf82ffd700) : INFO (init:223) - No subtitles available for language tur
2020-07-04 03:02:15,302 (7fdf82ffd700) : INFO (init:116) - Looking for match for GUID d6a208982fc59055 and size 8527988908
2020-07-04 03:02:15,377 (7fdf82ffd700) : INFO (init:126) - Found nothing via hash, trying search with imdbID: 2066051
2020-07-04 03:02:15,451 (7fdf82ffd700) : INFO (init:223) - No subtitles available for language fre
2020-07-04 03:02:15,451 (7fdf82ffd700) : INFO (init:116) - Looking for match for GUID d6a208982fc59055 and size 8527988908
2020-07-04 03:02:15,532 (7fdf82ffd700) : INFO (init:126) - Found nothing via hash, trying search with imdbID: 2066051
2020-07-04 03:02:15,604 (7fdf82ffd700) : INFO (init:223) - No subtitles available for language eng
2020-07-04 03:02:15,605 (7fdf82ffd700) : DEBUG (model:229) - Serializing to /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Metadata/Movies/0/83653a0a0dd5beb92d821f3a248559014fde483.bundle/Contents/com.plexapp.agents.opensubtitles/Info.xml
2020-07-04 03:02:15,605 (7fdf82ffd700) : DEBUG (runtime:88) - Sending packed state data (113 bytes)
2020-07-04 03:02:15,605 (7fdf82ffd700) : DEBUG (runtime:924) - Response: [200] str, 16 bytes
how to solve it ?
I cleared the cache tooo.
and I am not blocked by opensubtitles.org
Yeah. They had changed their url back a while ago. That miffed things up. I had to log in and reset my password and reselect my preferred subtitle language preferences on their site and then Plex started working again with subtitles once I authenticated again.
Hello
I have the same problem with the new Plex Movie agent, my .SRT files not load automatically, and when I refresh any movie, the subtitles that I have it, was deleted and I have to uploaded manually.
I have the same problem, no subtitles are downloaded automatically. I can even see SubZero in the agent settings and I ticked that but it does nothing. I don’t see Open Subtitles or any other plugin in there.
I have the exact same issue. I just reinstalled plex on docker, and set up my agents as they were before.
I realized after refreshing my library’s metadata that no subtitles were downloaded. I tried to download subtitles on a random video file and it worked. But the agent still didn’t download anything.
I stumbled upon this post in my research and I think I have a similar problem. I tried Ozkan134’s solution (even though I never had an opensubtitles.org account before.) I set my favorite languages on their site, changed my password there and in plex etc… It did not work.
I can’t exclude a misconfiguration on my new docker/plex, but with all the time spent, I still haven’t figured out why the agent won’t download anything.
Attached are my agent logs, I can’t see any errors. I can give other logs if they are relevant and needed.
Sadly, after stopping my plex container, removing the files from :
/Application Support/Plex Media Server/Plug-in Support/Caches
and
/Application Support/Plex Media Server/Cache
restarting my container, and refreshing my metadata on an item, I still don’t have any downloaded file.
I also tried removing/re-adding my opensubtitles account in the agent’s parameters.
The weird thing is that no cache folder is generated for opensubtitles after trying to refresh the metadata. It feels like the opensubtitles agent is not even starting.
