It’s in Swedish, but this is all that comes up during install
sorry, cant read swedish
are u sure you are running 32bit windows instead of 64bit windows? its kinda weird you would install 32bit to be honest nowdays. i would check your not actually infact running 64bit
Thank you very much for taking the time trying to help me.
It says “the computer doesn’t fulfill the minimum requirements to install the program”.
Yes I’m sure I’m running 32-bit.
The main reason for that is that I’m obviously stupid
WTF!!
I wrote a small novel as reply, but barely anything got posted
if it was me, id probably wipe and reinstall clean using 64bit, it likely wouldnt require a new licence key
I’ve taken this conversation to Intels forum asking about the drivers, but it seems to be a dead end. I am currently trying to upgrade to win10 64-bit, just like your saying.
Should have done this back at the upgrade from w7…
Thank you very much for your help and support
@OttoKerner said:
@nickbeek said:
I haven’t been able to find an explanation anywhere…It is a Client app for the Plex Server
https://support.plex.tv/hc/en-us/articles/200288286-What-is-Plex-
I have a Plex pass Server (Windows 7) and regular Plex Clients installed on every device in my home (xbox, shield, samsung tv, etc). Is there any way to host OpenPHT so that all of my client devices can access the fancy interface? Or you have to directly install OpenPHT onto each device, and only supports the operating systems listed on the GitHub page?
OpenPHT has to be installed on each client, you cant use it on either of those 3 devices you mentioned
Thank you guys for OpenPHT, you saved my mac mini-nas library.
Now i can also scroll via iPhone.
PlexMediaServer is slow, gives connection errors to the nas, spinning circle of death on Plex Mobile.
Thank you again guys.
Is OpenPHT dead?
