[root@localhost ~]# rpm -e plexmediaserver
error: Failed dependencies:
libexslt.so.0()(64bit) is needed by (installed) php-xml-5.4.16-46.el7.x86_64
libxslt.so.1()(64bit) is needed by (installed) php-xml-5.4.16-46.el7.x86_64
libxslt.so.1(LIBXML2_1.0.11)(64bit) is needed by (installed) php-xml-5.4.16-46.el7.x86_64
libxslt.so.1(LIBXML2_1.0.13)(64bit) is needed by (installed) php-xml-5.4.16-46.el7.x86_64
libxslt.so.1(LIBXML2_1.0.18)(64bit) is needed by (installed) php-xml-5.4.16-46.el7.x86_64
libxslt.so.1(LIBXML2_1.0.22)(64bit) is needed by (installed) php-xml-5.4.16-46.el7.x86_64
libxslt.so.1(LIBXML2_1.0.24)(64bit) is needed by (installed) php-xml-5.4.16-46.el7.x86_64
