Server Version#: DSM 7.0-41890 on DS218+
Player Version#: 1.24.1.4931
Hi, i installed plex after moving to DSM7, works fine.
I would like to upgrade to latest package 1.25.0.5282 (ARM v7 for x18 series version)
I have searched but cannot find the correct upgrade procedure, with all the installation issues I did not want to just assume that I should click “Manual Install” in package centre.
Could someone please advise?
Short: Download the package that is compatible with your cpu and manually install.
Plex Media Server for Synology DSM 7 - Release
This document is to share changes made with DSM 7 and resolve any unforeseen issues before you attempt migrating to DSM 7 for Plex use
YOU ARE URGED TO READ THIS THREAD COMPLETELY BEFORE PROCEEDING OR ASKING QUESTIONS
DO NOT INSTALL Synology BETA software UNLESS INSTRUCTED.
This thread is a LIVING document. Expect it to change.
Synology’s DiskStation Manager (DSM) has undergone significant changes in version 7.0.
Many of those changes affected …
andyb256:
If you have an existing DSM 7 installation running
NORMAL “Manual Install” (which is an “upgrade”)
There is nothing for you to do. It’s a normal Synology package update/upgrade.
Thanks both. Grabbed latest and did manual install and it worked fine.
Will it ever be the case that DSM7 identifies a package update is available for Plex? Or will it always need to be user decision from now on?
ChuckPa
December 3, 2021, 11:32pm
5
Synology controls Package Center.
There is always a delay from when we release a package until they publish it.
Sometimes it’s weeks, other times it’s months.
We are looking at alternatives but nothing solid yet.
system
Closed
March 3, 2022, 11:32pm
6
