PLEX on Synology DSM 7
Server Version#: 1.21.0.3744
Player Version#: 4.77.3
I notice the Synology package version of PLEX is 1.21.0.3744. There is a newer version. Is it safe to do a manual install on DSM 7 or should you keep using the original version.
I did update my DSM7 with version 1.25.8.5663 without any issue
@MikeMuhle
What you found in package center was the BETA app for use with DSM 7 BETA.
Synology has refused to update our app.
Please perform manual install to update.
The package will do the work for you.
Be patient with it as it moves the data around (if required).
Updating might take almost as long as initial migration.
I’ve been waiting for the package to come out of BETA before installing it. So it sounds like the package has already been released out of BETA, but just not in the package center? Is there any work / talk in progress with Synology to get it in the package center?
We’ve had several exchanges with Synology.
Each time, they find another reason to deny releasing it.
Please use Media Server Downloads | Plex Media Server for Windows, Mac, Linux, FreeBSD and More
