That should show you how to configure NFS sharing on the WD NAS.
Pay attention to Step 6, where you enter the IP addresses of devices that can access the WD using NFS. You will need to enter the IP address of the Terramaster, or use * to permit access from any device on the network.
You get to pick the mount point on the Terramaster.
If for example, on the Terramaster you have a folder named /media. You could make a subfolder, /wd. Then mount the shared folder from the WD to /media/wd. On the Terramaster, the path to the files would look like /media/wd/something, where something is the path on the WD - /media/wd/movies, /media/wd/tv, etc.
I do not know. I’ve never worked with a WD NAS. It could mean you are sharing all of Volume 1 or it could mean something else.
You have the shared folders from the WD mounted on your PC, correct?
Use that as a guide. It would look the same, or very similar, when you mount the WD on the Terramaster.
yes have the folders mounts on PC
\MYCLOUDEX2ULTRA\4k films
or \MYCLOUDEX2ULTRA\tv11
so with the plex on my PC currently I just enter \MYCLOUDEX2ULTRA\tv11 in the add folder then broswe for media and just enter in the top and that’s it
the same for terramaster I just enter like \TNAS\test that’s it it can find the folders and browse them the same with emby on the terramaster I just add folder click select path then network and its all there shared folders on the terramaster and wd cloud wish plex would make it this easy
I know a few years back we could browse cloud services and nas devices but for some reason plex has removed this
ok bit of a update not to sure what is happening but I have now noticed that even files on the terramaster don’t seem to be able to connect to the internet
what makes me think this is I added files from one folder 4k films that is whats on the terramaster so quite easy browse find and point to the folder
now the files are being added but they are all coming up as unmatched and when trying to match it cant find anything
any ideas what is going on and could this be why its not finding anything on the wd cloud ??
