When I open Plex Server it automatically tries to open in IE but needs to open in EDGE
When I open Plex Server it automatically tries to open in IE but I get a message indicating it no longer supports IE. It runs fine in Edge. How do I change the default program used to open the Plex in Edge?
That’s a Windows setting. https://support.microsoft.com/en-us/help/4028606/windows-10-change-your-default-browser
Do I need to change the default setting for Edge or Plex? Can you please tell me what specific setting I need to change?
You edit Edge. Set it as the default. If you don’t want edge as the default for everything, you’ll need to manually edit the options foe Edge. You’ll want the http and https protocols.
