I have a friend who has shared his server with me. When I open or start my server it always opens to his library. I have to scroll down to “MORE” to locate mine. is this normal?
You should not have it set to a Home Share but Friend. Then you will have your Libraries as default
at first launch of an app there is a wizard where you pick a server and the libraries from it you want pinned but you can change any time
The home.screen left side is just pinned libraries like Favorites. After you click More you can pin any libraries you want to the home screen. You can rearrange them in the home screen as well.
It may be faster, if you simply reset the whole sidebar and home page.
Make sure to select your own server during the procedure:
https://support.plex.tv/articles/customizing-the-mobile-apps-2#reset
https://support.plex.tv/articles/customizing-the-apps#reset
https://support.plex.tv/articles/customizing-plex-web#resethome
