When on HDMI Audio Source, Audio Only Works for Single Playback
Server Version#: 1.22.3.4523
Player Version#: 1.31.1.2262-74fdc6b7
Hey Guys -
Been using Plex for a long time and recently ran into issue on Plex Player installed on same system as server. Below is the behavior…
The below occurs only when HDMI audio source is selected…
  • Launch Plex and playback a title without issue
  • Start playing any 2nd title and there is no audio
  • Resolution is to close then relaunch Plex Player, but must do this after each single playback as issue repeats itself
  • Does not occur when any other audio device is selected
  • Audio works via HDMI from other apps when issue is occurring in Plex
I’ve attached a log where I did the following steps:
  1. Selected HDMI audio source
  2. Launched Plex and started playing a title - it has audio - then stopped playback after a few seconds,
  3. Started playback again (therefore experiencing issue of no audio)
  4. Stopped playback
  5. Closed Plex
Notes
  • Windows 10 1909 x64
  • Installed to same system as Plex server
  • Uninstalled Plex Desktop, deleted all related files from AppData, then reinstalled but issue persisted
Any suggestions appreciated - Thanks!
Plex.log (145.3 KB)
