Where are transcoded movies stored?
Hello,
I am transcoding a movie to upload it to the Amazon Cloud services. The original file is 6GB+ which will exceed the space on Amazon. Could anyone tell me, where the transcoded movies are stored, so that I can check the file size when transcoding is done?
I am running Plex on my Synology NAS.
Thank you.
unless you selected for them to be placed somewhere specifically i thought they went into a “Plex Versions” folder or similar in the same folder as the original files
I finally found the location on my NAS:
/volume1/Plex/Library/Application Support/Plex Media Server/Cache/Transcode/Sync+/7306603/ae/3962.mp4.temp
I have several folders like 7306603, I don’t know if it is per movie. After transcoding has finished, the file gets renamed to *.mp4
