Why are Tv episodes missing after fixing incorrect match?
I am trying to load Batman: The Animated Series. They released them in Volumes 1-4, but they are not in the original air date order. When I load them on Plex it puts them in the air date order instead of the volume order. I would like them in the volume order so the titles match what episode really is. I went to Fix Incorrect Match to see if any of the other databases offered the volume order. It ordered the episodes correctly, but it deleted Volume 4. I deleted the entire show and reloaded all 4 volumes and all 4 were present when Plex ordered them by air date instead of volume. I tried fixing the incorrect match again and it ordered Volumes 1-3 fine, but deleted volume 4 again. Any ideas? Thanks.
I’m not sure if the DVD Order Agent would help you, but here is a thread rivaling War and Peace that will (may) help you get it installed so you can find out:
It works like a charm for Firefly, but I will tell you I did name the files properly first, then ran the Agent and all is well.
